주요 콘텐츠로 건너뛰기
Disassembling Canon Powershot SD880 Logic Board
필요한 것
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: 1 단계, 이미지 1/3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: 1 단계, 이미지 2/3 Disassembling Canon Powershot SD880 Logic Board, Back Cover: 1 단계, 이미지 3/3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: 2 단계, 이미지 1/3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: 2 단계, 이미지 2/3 Disassembling Canon Powershot SD880 Logic Board, Front Cover: 2 단계, 이미지 3/3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: 3 단계, 이미지 1/2 Disassembling Canon Powershot SD880 Logic Board, Top Panel: 3 단계, 이미지 2/2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: 4 단계, 이미지 1/1
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: 5 단계, 이미지 1/2 Disassembling Canon Powershot SD880 Logic Board: 5 단계, 이미지 2/2
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
결론
Juan Miguel
회원 가입일: 01/13/11
101 평판
안내서 1개 작성함
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 회원
CPSU-FORTE-W11S13G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 2,019
