부품
부품은 필요하지 않습니다.
  1. Remove all four screws on the side of camera with speaker.
    • Remove all four screws on the side of camera with speaker.
  2. Remove all four screws from side of camera with wristband attachment.
    • Remove all four screws from side of camera with wristband attachment.
    • Remove all four screws on bottom of camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Logan
회원 가입일: 2011년 01월 10일
311 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 회원
CPSU-REGAN-W11S4G38
4 회원들
안내서 7개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 2,795
