주요 콘텐츠로 건너뛰기
Disassembling Circo Monkey Alarm Clock Clock Face
필요한 것
  1. Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: 1 단계, 이미지 3개 중 1개 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: 1 단계, 이미지 3개 중 2개 Disassembling Circo Monkey Alarm Clock Clock Face, Disassembling Circo Monkey Alarm Clock Clock Face: 1 단계, 이미지 3개 중 3개
    • Grasp the plastic cover and carefully pull straight back so that the clock cover dislodges from its housing.
    • If any additional assistance is required for this step, it is recommended to use the plastic opening tool to help pry the edges of the cover simultaneously or a suction cup if you cannot grip the rim.
  2. Disassembling Circo Monkey Alarm Clock Clock Face: 2 단계, 이미지 1개 중 1개
    • Using your fingers, grasp the point where the hands of the clock meet in the center and pull straight back until they dislodge from the motor.
    • Be sure that you remove all three hands as well as the pin that connects them in this one step. This component should come out as a single piece.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Devin Gooding
회원 가입일: 01/20/15
110 평판
안내서 1개를 작성함
USF Tampa, Team 19-1, Blackwell Winter 2015 USF Tampa, Team 19-1, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S19G1
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 755
