주요 콘텐츠로 건너뛰기
Disassembling Dell Inspiron Duo Front Cover
필요한 것
  1. Disassembling Dell Inspiron Duo Front Cover, Front Cover: 1 단계, 이미지 1/2 Disassembling Dell Inspiron Duo Front Cover, Front Cover: 1 단계, 이미지 2/2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
  2. Disassembling Dell Inspiron Duo Front Cover: 2 단계, 이미지 1/2 Disassembling Dell Inspiron Duo Front Cover: 2 단계, 이미지 2/2
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
  3. Disassembling Dell Inspiron Duo Front Cover: 3 단계, 이미지 1/2 Disassembling Dell Inspiron Duo Front Cover: 3 단계, 이미지 2/2
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Amrit Multani
회원 가입일: 07/14/15
115 평판
안내서 1개 작성함
UW Tacoma, Team 1-1, Liner SU 2015 UW Tacoma, Team 1-1, Liner SU 2015 회원
UWT-LINER-SU15S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Can I get a broken screen
Daniel Mwangi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 22
전체 시간: 945
