소개
We'll remove the top cover from the device, allowing the other components to be seen and replaced or repaired.
필요한 것
Flip your device over so the bottom panel is facing up.
To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
다른 2명이 해당 안내서를 완성하였습니다.
