주요 콘텐츠로 건너뛰기
Disassembling Dell Inspiron One 2020 Back Cover
필요한 것
  1. Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: 1 단계, 이미지 1/3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: 1 단계, 이미지 2/3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: 1 단계, 이미지 3/3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Disassembling Dell Inspiron One 2020 Back Cover: 2 단계, 이미지 1/3 Disassembling Dell Inspiron One 2020 Back Cover: 2 단계, 이미지 2/3 Disassembling Dell Inspiron One 2020 Back Cover: 2 단계, 이미지 3/3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Disassembling Dell Inspiron One 2020 Back Cover: 3 단계, 이미지 1/3 Disassembling Dell Inspiron One 2020 Back Cover: 3 단계, 이미지 2/3 Disassembling Dell Inspiron One 2020 Back Cover: 3 단계, 이미지 3/3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
결론
다른 28명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 06/19/12
4,920 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 25개 작성하였습니다
댓글 한 개
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 77
전체 시간: 33,907
