소개
Shows how to remove/replace any part on a Dell Vostro V13 laptop.
도구
부품
지정된 부품이 없습니다.
Remove the two (2) dummy cards from the laptop.
Using a Phillips head screwdriver, unscrew the six (6) screws from the bottom of the laptop.
Unscrew the two (2) screws from the back of the laptop, located at the extreme left and right of the back panel.
Slide bottom cover forward and lift upwards to remove. You may need to use a strong spudger to force a gap along the base edge from the ethernet port on the right, to the kensington port on the left.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 2개
is the CPU removable?
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
Chris Yang - 답글
