소개
This guide explains how to remove/replace any part on a Dell Vostro V13 laptop by describing a complete tear-down. Any screwdriver of size PH00 to PH1 will work with the screws on this laptop.
필요한 것
Remove the two plastic dummy cards from the laptop.
Unscrew the six PH00 screws from the bottom of the laptop.
Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
Slide the bottom cover forward and lift it upwards to remove.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 2개
is the CPU removable?
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
Chris Yang - 답글
