주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Disassembling Dell Vostro V13
필요한 것
  1. Disassembling Dell Vostro V13, Disassembling Dell Vostro V13: 1 단계, 이미지 1/3 Disassembling Dell Vostro V13, Disassembling Dell Vostro V13: 1 단계, 이미지 2/3 Disassembling Dell Vostro V13, Disassembling Dell Vostro V13: 1 단계, 이미지 3/3
    • Remove the two (2) dummy cards from the laptop.
    • Using a Phillips head screwdriver, unscrew the six (6) screws from the bottom of the laptop.
    • Unscrew the two (2) screws from the back of the laptop, located at the extreme left and right of the back panel.
    • Slide bottom cover forward and lift upwards to remove. You may need to use a strong spudger to force a gap along the base edge from the ethernet port on the right, to the kensington port on the left.
  2. Disassembling Dell Vostro V13: 2 단계, 이미지 1/1
    • Carefully remove the battery connector. It is a ribbon cable that is clamped down. Flick the black clamp up using the edge nearest the battery. The ribbon cable is now free to move for the next step.
    • Unscrew the four (4) screws from the battery.
    • Lift the battery upwards, to remove.
  3. Disassembling Dell Vostro V13: 3 단계, 이미지 1/2 Disassembling Dell Vostro V13: 3 단계, 이미지 2/2
    • Unscrew the four (4) screws from the hard drive enclosure.
    • Gently lift the hard drive at a small angle upwards and slide it in the direction of the arrow to remove.
    • To avoid damaging the port, GENTLY lift the hard drive at a SMALL angle upward, when removing it!
  4. Disassembling Dell Vostro V13: 4 단계, 이미지 1/2 Disassembling Dell Vostro V13: 4 단계, 이미지 2/2
    • Using a plastic opening tool, pry open the top panel, with the power switch, starting with the right bottom edge closer to the keyboard.
    • Unclip and remove the ribbon from the panel.
    • Always be careful when removing ribbons! Try not to unnecessarily bend them and pull them with excess force!
  5. Disassembling Dell Vostro V13: 5 단계, 이미지 1/2 Disassembling Dell Vostro V13: 5 단계, 이미지 2/2
    • Unscrew the two (2) screws from the keyboard.
    • Gently lift the keyboard upwards and push towards the screen to remove.
    • Remove the ribbon from the board.
  6. Disassembling Dell Vostro V13: 6 단계, 이미지 1/2 Disassembling Dell Vostro V13: 6 단계, 이미지 2/2
    • Remove all the ribbons from the board.
    • Unscrew the one (1) screw from the audio card and lift upward to remove.
  7. Disassembling Dell Vostro V13: 7 단계, 이미지 1/2 Disassembling Dell Vostro V13: 7 단계, 이미지 2/2
    • Unscrew the six (6) screws from the memory card reader.
    • Make sure that a hand is placed underneath to hold the memory card reader while unscrewing, so it won't fall.
    • Remove the cable from the CMOS battery.
  8. Disassembling Dell Vostro V13: 8 단계, 이미지 1/1
    • Using a small plastic opening tool, gently lift and remove the two (2) antenna cables from the wireless card.
    • Unscrew the one (1) screw.
    • The wireless card should pop up.
    • Gently slide the card forward to remove.
  9. Disassembling Dell Vostro V13: 9 단계, 이미지 1/2 Disassembling Dell Vostro V13: 9 단계, 이미지 2/2
    • Unscrew the six (6) screws from the motherboard.
    • Unscrew the two (2) screws from the fan.
    • Gently lift the motherboard upward and then slide forward to remove.
    • Be extremely careful with the motherboard! Damage to any of the components on it would cause the laptop to malfunction!
  10. Disassembling Dell Vostro V13: 10 단계, 이미지 1/1
    • Press the two (2) metal clips on the side and the RAM will pop out.
    • Pull forward to remove.
  11. Disassembling Dell Vostro V13: 11 단계, 이미지 1/1
    • Unscrew the four (4) screws from the heat sink.
    • Unscrew the one (1) screw from the fan.
    • Pull the heat sink with the fan upward to remove.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Kevin Dookharan
회원 가입일: 08/23/12
383 평판
안내서 1개 작성함
댓글 2개
is the CPU removable?
Trevor Vuong - 답글
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
Chris Yang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 55
전체 시간: 37,873
