주요 콘텐츠로 건너뛰기
Disassembling Epson PPC650 Replacing Flash
필요한 것
  1. Disassembling Epson PPC650 Replacing Flash, Case: 1 단계, 이미지 1/3 Disassembling Epson PPC650 Replacing Flash, Case: 1 단계, 이미지 2/3 Disassembling Epson PPC650 Replacing Flash, Case: 1 단계, 이미지 3/3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Disassembling Epson PPC650 Replacing Flash: 2 단계, 이미지 1/1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Disassembling Epson PPC650 Replacing Flash: 3 단계, 이미지 1/2 Disassembling Epson PPC650 Replacing Flash: 3 단계, 이미지 2/2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Disassembling Epson PPC650 Replacing Flash: 4 단계, 이미지 1/1
    • Remove 4 screws from the bottom of the camera
  5. Disassembling Epson PPC650 Replacing Flash: 5 단계, 이미지 1/3 Disassembling Epson PPC650 Replacing Flash: 5 단계, 이미지 2/3 Disassembling Epson PPC650 Replacing Flash: 5 단계, 이미지 3/3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 6 단계, 이미지 1/3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 6 단계, 이미지 2/3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: 6 단계, 이미지 3/3
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
  7. Disassembling Epson PPC650 Replacing Flash: 7 단계, 이미지 1/1
    • Remove clear rubber band holding flash in line with wiring.
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
결론
Xan Danes
회원 가입일: 02/14/13
122 평판
안내서 1개 작성함
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 273
