주요 콘텐츠로 건너뛰기
Disassembling Ericsson CF 388 Circuit Board
필요한 것
  1. Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 1/3 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 2/3 Disassembling Ericsson CF 388 Circuit Board, Disassembling Ericsson CF 388 Battery: 1 단계, 이미지 3/3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 2 단계, 이미지 1/3 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 2 단계, 이미지 2/3 Disassembling Ericsson CF 388 Circuit Board, Phone Casing: 2 단계, 이미지 3/3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Circuit Board: 3 단계, 이미지 1/3 Disassembling Ericsson CF 388 Circuit Board: 3 단계, 이미지 2/3 Disassembling Ericsson CF 388 Circuit Board: 3 단계, 이미지 3/3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Circuit Board: 4 단계, 이미지 1/2 Disassembling Ericsson CF 388 Circuit Board: 4 단계, 이미지 2/2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
  5. Disassembling Ericsson CF 388 Circuit Board, Circuit Board: 5 단계, 이미지 1/1
    • Locate the circuit board on the rear side of the front phone casing (right side of image).
    • Locate the mounting screws (indicated by red circles), which attach the board to the rear side of the front phone casing.
  6. Disassembling Ericsson CF 388 Circuit Board: 6 단계, 이미지 1/3 Disassembling Ericsson CF 388 Circuit Board: 6 단계, 이미지 2/3 Disassembling Ericsson CF 388 Circuit Board: 6 단계, 이미지 3/3
    • Using the SP2.6 u-shaped screw driver in one hand, loosen and remove both center screws. Hold the back part of the screw with the metal tweezers.
  7. Disassembling Ericsson CF 388 Circuit Board: 7 단계, 이미지 1/2 Disassembling Ericsson CF 388 Circuit Board: 7 단계, 이미지 2/2
    • Completely remove the two center screw as shown.
    • Note: the hand not holding the screw driver is holding the back part of the screw and the panel in place.
  8. Disassembling Ericsson CF 388 Circuit Board: 8 단계, 이미지 1/2 Disassembling Ericsson CF 388 Circuit Board: 8 단계, 이미지 2/2
    • Locate the final screw at the top of the phone near the antenna, as shown by the red circle.
    • Using the U-shaped screw driver, remove the top screw.
  9. Disassembling Ericsson CF 388 Circuit Board: 9 단계, 이미지 1/2 Disassembling Ericsson CF 388 Circuit Board: 9 단계, 이미지 2/2
    • With one hand on the circuit board and one hand on the phone casing, carefully pull apart the circuit board from the front panel casing.
결론
Niccolas Tones
회원 가입일: 03/09/12
60 평판
안내서 9개 작성하였습니다
Clemson, Team 1-1, Benson Spring 2012 Clemson, Team 1-1, Benson Spring 2012 회원
CLEM-BENSON-S12S1G1
3 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,266
