주요 콘텐츠로 건너뛰기
Disassembling Eureka 1660SP Motor Housing
필요한 것
  1. Disassembling Eureka 1660SP Motor Housing, Motor Housing: 1 단계, 이미지 1/2 Disassembling Eureka 1660SP Motor Housing, Motor Housing: 1 단계, 이미지 2/2
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Disassembling Eureka 1660SP Motor Housing: 2 단계, 이미지 1/2 Disassembling Eureka 1660SP Motor Housing: 2 단계, 이미지 2/2
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Disassembling Eureka 1660SP Motor Housing: 3 단계, 이미지 1/3 Disassembling Eureka 1660SP Motor Housing: 3 단계, 이미지 2/3 Disassembling Eureka 1660SP Motor Housing: 3 단계, 이미지 3/3
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jennifer Sheils
회원 가입일: 09/07/13
4 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 346
