주요 콘텐츠로 건너뛰기
Disassembling Fifine T683 Microphone Body
필요한 것
  1. Disassembling Fifine T683 Microphone Body, The Microphone: 1 단계, 이미지 1/1
    • This is a well built all-metal condenser microphone.
  2. Disassembling Fifine T683 Microphone Body: 2 단계, 이미지 1/1
    • Remove the gain dial, this slips off easily with a tug.
  3. Disassembling Fifine T683 Microphone Body: 3 단계, 이미지 1/2 Disassembling Fifine T683 Microphone Body: 3 단계, 이미지 2/2
    • Remove the hard plastic ring that is covering the 2 phillips screws at the bottom of the unit.
  4. Disassembling Fifine T683 Microphone Body: 4 단계, 이미지 1/1
    • Removing the 2 screws will release the filter. Note that there should be 2 brass poles that connects the two pieces together. One broke in the picture shown as I pried it before.
  5. Disassembling Fifine T683 Microphone Body: 5 단계, 이미지 1/2 Disassembling Fifine T683 Microphone Body: 5 단계, 이미지 2/2
    • The condenser is not attached to the casing and is easily removeable. It is connected to the main PCB so do be careful.
  6. Disassembling Fifine T683 Microphone Body: 6 단계, 이미지 1/1
    • Inside you will see another smaller PCB that housed the 3.5mm audio jack. This needs to be removed first before the main PCB as the USB connector is slightly too large to slide through.
  7. Disassembling Fifine T683 Microphone Body: 7 단계, 이미지 1/2 Disassembling Fifine T683 Microphone Body: 7 단계, 이미지 2/2
    • There two screws to remove the smaller PCB.
  8. Disassembling Fifine T683 Microphone Body: 8 단계, 이미지 1/1
    • Two more screws on the sides to be removed.
  9. Disassembling Fifine T683 Microphone Body: 9 단계, 이미지 1/1
    • Congratulations! now you're free to work on the PCB.
결론
clem
회원 가입일: 05/08/19
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 21
전체 시간: 59
