주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling Flat Iron Remington S-3500
필요한 것
  1. Disassembling Flat Iron Remington S-3500, What it looks like: 1 단계, 이미지 2개 중 1개 Disassembling Flat Iron Remington S-3500, What it looks like: 1 단계, 이미지 2개 중 2개
    • What the flat IRON looks like
  2. Disassembling Flat Iron Remington S-3500: 2 단계, 이미지 2개 중 1개 Disassembling Flat Iron Remington S-3500: 2 단계, 이미지 2개 중 2개
    • Locate and remove the Hinge caps (One on each side)
    • On one side there will be a Philips screw below the cap
    • Take care. Screws seem quite soft, so find a well matching screwdriver
  3. Disassembling Flat Iron Remington S-3500: 3 단계, 이미지 1개 중 1개
    • Here you see the caps
    • Then the two "tube" like parts of the hinge/axle
    • Then comes the spring that forces the arms apart (Which came out just above where it is seen in the picture
  4. Disassembling Flat Iron Remington S-3500: 4 단계, 이미지 1개 중 1개
    • You can now access the three screws holding back the covers in both sides.
  5. Disassembling Flat Iron Remington S-3500: 5 단계, 이미지 1개 중 1개
    • Notice the spring to the right, when you put it together again
  6. Disassembling Flat Iron Remington S-3500: 6 단계, 이미지 1개 중 1개
    • The swivel on the mains cord is held back by 2 screws also easily accessible when the arms are separated
    • I bend the small pickups in the white part a little bit to make then just a bit tighter. (I dont know if this was the loose connection, but after assembly the blue light signalling heating started working again)
    • Caution, the parts inside carry (in my case 230 Volts) So checking for loose connections while taken apart should be done with an Ohm Meter or similar.
결론
작성자
1다른 기여자 명과 함께
Henrik Wahlberg
회원 가입일: 04/27/20
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 33
전체 시간: 264
