소개
This guide will show you how to open your Flip Video and remove the main circuit board.
부품
지정된 부품이 없습니다.
  1. Turn off the device and take the batteries out. Remove metal sticker under the LCD screen with a spudger.
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell. Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  5. Open battery door. This can be done by gently depressing and sliding the battery down downward.
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  6. Use the spudger to separate outer shells.
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  7. Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  8. Slowly lift the left side of the circuit board.
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  9. Disconnect the USB port cable from the back side of the circuit board.
    • Disconnect the USB port cable from the back side of the circuit board.
  10. Slide out the battery contacts.
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elizabeth
회원 가입일: 2010년 04월 15일
100 Reputation
안내서 6개 작성하였습니다
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 회원
CPSU-REGAN-S10S26G21
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - 답글
댓글 쓰기
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,048
