소개
Removing the outer case of the camera.
부품
No parts specified.
  1. Remove the batteries from the camera to prevent danger of electric shock.
    • Remove the batteries from the camera to prevent danger of electric shock.
  2. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws.
    • Locate all five screws on the camera. Then proceed to remove all the screws.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
    • Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
    • If your screwdriver does not fit, or you do not have the proper one, you can use a hot glue gun to fix the screwdriver to the head of the screw. Wait for it to harden slightly, and then try to remove the screws.
  5. Remove outer case.  Pull the back away from the main body of the camera. Remove outer case.  Pull the back away from the main body of the camera.
    • Remove outer case. Pull the back away from the main body of the camera.
결론
Cody
회원 가입일: 2010년 04월 18일
47 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010 회원
CPSU-MANESS-S10S7G11
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 3,409
