주요 콘텐츠로 건너뛰기
Disassembling Galaxy Tab S 10.5 Back Cover
필요한 것
  1. Disassembling Galaxy Tab S 10.5 Back Cover, Disassembling Galaxy Tab S 10.5 Back Cover: 1 단계, 이미지 1/2 Disassembling Galaxy Tab S 10.5 Back Cover, Disassembling Galaxy Tab S 10.5 Back Cover: 1 단계, 이미지 2/2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Disassembling Galaxy Tab S 10.5 Back Cover: 2 단계, 이미지 1/1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Disassembling Galaxy Tab S 10.5 Back Cover: 3 단계, 이미지 1/1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Jordan Soto
회원 가입일: 08/26/15
3,276 평판
안내서 6개 작성하였습니다
USF Tampa, Team 3-2, Eyestone Fall 2015 USF Tampa, Team 3-2, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G2
3 회원들
안내서 20개 작성하였습니다
댓글 6개
This is very misleading and not the correct way to open this device. This will damage the backplate and the antennas that are glued together. The proper way to open this tablet is from the front taking the LCD out of the frame.
jamee - 답글
I have completed this disassembly multiple times without issue. There is nothing glued to that part of the unit.
G C -
I disassembled and assembled back SM-T805 for motherboard replacement 2 hours ago. Discovered that back cover have a row of tiny pins with tips molded into back cover rim who are designed to break out and larger pins who will click open and back on closing just fine. Also back cover rim is glued to cover with weak glue. Seems someone Samsung decided that those larger pins alone are not enough to keep back cover firmly in place without flapping around. In reality larger pins alone on assembling will click back and keep cover in place just fine.
However I agree to you that correct way is to carefully open this tablet from screen side with these small blue flat openers or with plastic cards. It will be faster as well. Back cover rim should be removed only to replace antennas. I hope that author of these manuals will fix that.
Jānis Baumanis -
Jamee is right, the SM-T805 (3G) can be opened separating the cover from the LCD, and not by removing that back cover that is glued to the rest.
German Palacio - 답글
How can I get another charging female component
peter toombs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 31
30일 전: 136
전체 시간: 38,511
