주요 콘텐츠로 건너뛰기
Disassembling Garmin Nuvi 1200 Logic Board
필요한 것
  1. Disassembling Garmin Nuvi 1200 Logic Board, Logic Board: 1 단계, 이미지 1/1
    • Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
    • Once the tool is inserted it can slide around the entire device.
  2. Disassembling Garmin Nuvi 1200 Logic Board: 2 단계, 이미지 1/1
    • Remove four small T5 torx screws.
    • Be gentle, the screws are easily stripped.
  3. Disassembling Garmin Nuvi 1200 Logic Board: 3 단계, 이미지 1/2 Disassembling Garmin Nuvi 1200 Logic Board: 3 단계, 이미지 2/2
    • Lift cover off of unit.
    • Be careful not to lose small rubber piece on the bottom right corner.
  4. Disassembling Garmin Nuvi 1200 Logic Board: 4 단계, 이미지 1/1
    • Disconnect ribbon cable from logic board.
  5. Disassembling Garmin Nuvi 1200 Logic Board: 5 단계, 이미지 1/1
    • Remove two T5 torx screws holding down logic board.
    • Disconnect battery.
  6. Disassembling Garmin Nuvi 1200 Logic Board: 6 단계, 이미지 1/1
    • Gently lift the logic board out of the unit
    • Be careful not to damage the battery connector on the top of the unit.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Zachary Landau
회원 가입일: 11/28/10
206 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 9
전체 시간: 5,232
