소개
This guide will explain how to remove the outer case of the General Electric Bagel Switch 4-Slice Toaster.
부품
부품은 필요하지 않습니다.
  1. Unplug the toaster from the electrical outlet.
    • Unplug the toaster from the electrical outlet.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Remove the two levers and four dials by pulling them out directly towards you. Removing these components may require some force, but they will release.
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
  4. Look for the plastic clips on the back side of the toaster.
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
결론
Ron Gajdos
회원 가입일: 2013년 10월 16일
307 평판
안내서 3개 작성하였습니다
University of Maryland, Team 4-4, Vijaybhaskar Fall 2013 University of Maryland, Team 4-4, Vijaybhaskar Fall 2013 회원
UMD-VIJAYBHASKAR-F13S4G4
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 564
