주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling General Electric Telephone 2-9710A Handset
필요한 것
  1. Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: 1 단계, 이미지 2개 중 1개 Disassembling General Electric Telephone 2-9710A Handset, Phone Cord: 1 단계, 이미지 2개 중 2개
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. Disassembling General Electric Telephone 2-9710A Handset: 2 단계, 이미지 3개 중 1개 Disassembling General Electric Telephone 2-9710A Handset: 2 단계, 이미지 3개 중 2개 Disassembling General Electric Telephone 2-9710A Handset: 2 단계, 이미지 3개 중 3개
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: 3 단계, 이미지 2개 중 1개 Disassembling General Electric Telephone 2-9710A Handset, General Electric Telephone 2-9710A Handset: 3 단계, 이미지 2개 중 2개
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. Disassembling General Electric Telephone 2-9710A Handset: 4 단계, 이미지 1개 중 1개
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. Disassembling General Electric Telephone 2-9710A Handset: 5 단계, 이미지 2개 중 1개 Disassembling General Electric Telephone 2-9710A Handset: 5 단계, 이미지 2개 중 2개
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. Disassembling General Electric Telephone 2-9710A Handset: 6 단계, 이미지 2개 중 1개 Disassembling General Electric Telephone 2-9710A Handset: 6 단계, 이미지 2개 중 2개
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. Disassembling General Electric Telephone 2-9710A Handset: 7 단계, 이미지 1개 중 1개
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. Disassembling General Electric Telephone 2-9710A Handset: 8 단계, 이미지 2개 중 1개 Disassembling General Electric Telephone 2-9710A Handset: 8 단계, 이미지 2개 중 2개
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. Disassembling General Electric Telephone 2-9710A Handset: 9 단계, 이미지 2개 중 1개 Disassembling General Electric Telephone 2-9710A Handset: 9 단계, 이미지 2개 중 2개
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. Disassembling General Electric Telephone 2-9710A Handset: 10 단계, 이미지 1개 중 1개
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
결론
작성자
12다른 기여자 명과 함께
Alles Rebel
회원 가입일: 09/20/12
72 평판
안내서 3개를 작성함
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012 회원
CPSU-FORTE-F12S16G59
4 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 23
지난 30일: 85
전체 시간: 3,409
