소개
There are no prerequisites required for this disassembly, but a spudger or similar opening tool is required to remove the panel.
부품
No parts specified.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
결론
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
회원 가입일: 2012년 03월 09일
101 평판
안내서 9개 작성하였습니다
Clemson, Team 15-3, Benson Spring 2012 Clemson, Team 15-3, Benson Spring 2012 회원
CLEM-BENSON-S12S15G3
3 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,014
