주요 콘텐츠로 건너뛰기
Griffin iFM 4027 Left Side Panel Replacement
필요한 것
  1. Griffin iFM 4027 Left Side Panel Replacement, Left Side Panel: 1 단계, 이미지 1/1
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  2. Griffin iFM 4027 Left Side Panel Replacement: 2 단계, 이미지 1/3 Griffin iFM 4027 Left Side Panel Replacement: 2 단계, 이미지 2/3 Griffin iFM 4027 Left Side Panel Replacement: 2 단계, 이미지 3/3
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
결론
Alexander
회원 가입일: 03/09/12
101 평판
안내서 6개 작성하였습니다
Clemson, Team 15-3, Benson Spring 2012 Clemson, Team 15-3, Benson Spring 2012 회원
CLEM-BENSON-S12S15G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 14
전체 시간: 1,130
