주요 콘텐츠로 건너뛰기
Disassembling HP Compaq dx2000MT Hard Drive
필요한 것
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: 1 단계, 이미지 1/1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: 2 단계, 이미지 1/2 Disassembling HP Compaq dx2000MT Hard Drive: 2 단계, 이미지 2/2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: 3 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive: 3 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive: 3 단계, 이미지 3/3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: 4 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive: 4 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive: 4 단계, 이미지 3/3
    • Once again, this may take considerable force.
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 5 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 5 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: 5 단계, 이미지 3/3
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: 6 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive: 6 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive: 6 단계, 이미지 3/3
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. Disassembling HP Compaq dx2000MT Hard Drive: 7 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive: 7 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive: 7 단계, 이미지 3/3
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: 8 단계, 이미지 1/2 Disassembling HP Compaq dx2000MT Hard Drive: 8 단계, 이미지 2/2
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: 9 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive: 9 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive: 9 단계, 이미지 3/3
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: 10 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive: 10 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive: 10 단계, 이미지 3/3
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: 11 단계, 이미지 1/3 Disassembling HP Compaq dx2000MT Hard Drive: 11 단계, 이미지 2/3 Disassembling HP Compaq dx2000MT Hard Drive: 11 단계, 이미지 3/3
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: 12 단계, 이미지 1/2 Disassembling HP Compaq dx2000MT Hard Drive: 12 단계, 이미지 2/2
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Eva Pong
회원 가입일: 09/22/11
101 평판
안내서 1개 작성함
Cal Poly, Team 17-16, Regan Fall 2011 Cal Poly, Team 17-16, Regan Fall 2011 회원
CPSU-REGAN-F11S17G16
4 회원들
안내서 17개 작성하였습니다
댓글 2개
can i upgrade it to 500gb?
connor gouws - 답글
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
Thomas Daniel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 39
전체 시간: 8,230
