주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In order to gain access to most of the internal components the top (or lid) of the printer must be removed. This guide is intended as a prerequisite for other installations.
부품
지정된 부품이 없습니다.
  1. Open the front access panel by placing your finger in the front slot and pulling gently.
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
    • Remove the four 9mm T10 Torx screws on the top.
  4. Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
결론
다른 21명이 해당 안내서를 완성하였습니다.
Tim
회원 가입일: 2013년 01월 15일
184 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 회원
CPSU-REGAN-W13S18G35
5 회원들
안내서 8개 작성하였습니다
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 59
전체 시간: 8,418
