주요 콘텐츠로 건너뛰기
Disassembling HP Envy TouchSmart 15 Back Plate
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Disassembling HP Envy TouchSmart 15 Back Plate, Battery: 1 단계, 이미지 1개 중 1개
    • Press the battery release tab and the battery will pop up.
  2. Disassembling HP Envy TouchSmart 15 Back Plate: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the laptop, it will come out easily.
  3. Disassembling HP Envy TouchSmart 15 Back Plate, Accessory Plate: 3 단계, 이미지 2개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate, Accessory Plate: 3 단계, 이미지 2개 중 2개
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. Disassembling HP Envy TouchSmart 15 Back Plate: 4 단계, 이미지 3개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate: 4 단계, 이미지 3개 중 2개 Disassembling HP Envy TouchSmart 15 Back Plate: 4 단계, 이미지 3개 중 3개
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. Disassembling HP Envy TouchSmart 15 Back Plate, Solid State Drive: 5 단계, 이미지 2개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate, Solid State Drive: 5 단계, 이미지 2개 중 2개
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  6. Disassembling HP Envy TouchSmart 15 Back Plate: 6 단계, 이미지 2개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate: 6 단계, 이미지 2개 중 2개
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
  7. Disassembling HP Envy TouchSmart 15 Back Plate, Hard Drive: 7 단계, 이미지 2개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate, Hard Drive: 7 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
  8. Disassembling HP Envy TouchSmart 15 Back Plate: 8 단계, 이미지 2개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate: 8 단계, 이미지 2개 중 2개
    • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
  9. Disassembling HP Envy TouchSmart 15 Back Plate, Back Plate: 9 단계, 이미지 3개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate, Back Plate: 9 단계, 이미지 3개 중 2개 Disassembling HP Envy TouchSmart 15 Back Plate, Back Plate: 9 단계, 이미지 3개 중 3개
    • Remove the highlighted rubber stoppers with a metal spudger as pictured. They should expose a screw that you will need to remove in a later step.
  10. Disassembling HP Envy TouchSmart 15 Back Plate: 10 단계, 이미지 3개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate: 10 단계, 이미지 3개 중 2개 Disassembling HP Envy TouchSmart 15 Back Plate: 10 단계, 이미지 3개 중 3개
    • Remove plastic cover highlighted. It should expose a screw that you will need in a later step.
  11. Disassembling HP Envy TouchSmart 15 Back Plate: 11 단계, 이미지 1개 중 1개
    • Remove all highlighted screws with PH 1 screwdriver. These screws are PM 2.0x2.5.
  12. Disassembling HP Envy TouchSmart 15 Back Plate: 12 단계, 이미지 2개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate: 12 단계, 이미지 2개 중 2개
    • Remove all highlighted screws from the battery access area. These are PM 1.5x2.0 screws
  13. Disassembling HP Envy TouchSmart 15 Back Plate: 13 단계, 이미지 1개 중 1개
    • Remove screws highlighted with PH1 screwdriver from accessory plate area.These are PM 2.5x3.0 screws
    • Remove screws highlighted with PH1 screwdriver from accessory plate area. These are PM 2.5x4.5 screws
  14. Disassembling HP Envy TouchSmart 15 Back Plate: 14 단계, 이미지 3개 중 1개 Disassembling HP Envy TouchSmart 15 Back Plate: 14 단계, 이미지 3개 중 2개 Disassembling HP Envy TouchSmart 15 Back Plate: 14 단계, 이미지 3개 중 3개
    • Pry open back plate area with plastic opening tool. The back plate should pry open with relative ease. If you feel some resistance at any point please refer to steps 2-5 because a screw has probably been missed.
결론
작성자
4다른 기여자 명과 함께
Ramon Villadonga
회원 가입일: 09/04/15
1,035 평판
안내서 5개를 작성함
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G6
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 4
전체 시간: 66
