주요 콘텐츠로 건너뛰기
Disassembling HP Mini 110-1046NR Memory Card Cover
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Disassembling HP Mini 110-1046NR Memory Card Cover, Battery: 1 단계, 이미지 1/3 Disassembling HP Mini 110-1046NR Memory Card Cover, Battery: 1 단계, 이미지 2/3 Disassembling HP Mini 110-1046NR Memory Card Cover, Battery: 1 단계, 이미지 3/3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. Disassembling HP Mini 110-1046NR Memory Card Cover, Memory Card Cover: 2 단계, 이미지 1/3 Disassembling HP Mini 110-1046NR Memory Card Cover, Memory Card Cover: 2 단계, 이미지 2/3 Disassembling HP Mini 110-1046NR Memory Card Cover, Memory Card Cover: 2 단계, 이미지 3/3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
결론
Jared Cooper
회원 가입일: 10/18/13
649 평판
안내서 5개 작성하였습니다
Clemson, Team 14-1, Benson Fall 2013 Clemson, Team 14-1, Benson Fall 2013 회원
CLEM-BENSON-F13S14G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55
