주요 콘텐츠로 건너뛰기
Disassembling HP Pavilion g7-2275dx Front Panel
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Disassembling HP Pavilion g7-2275dx Front Panel, Front Panel: 1 단계, 이미지 1/1
    • Unscrew the four 7 mm Phillips #1 screws on the board.
  2. Disassembling HP Pavilion g7-2275dx Front Panel: 2 단계, 이미지 1/3 Disassembling HP Pavilion g7-2275dx Front Panel: 2 단계, 이미지 2/3 Disassembling HP Pavilion g7-2275dx Front Panel: 2 단계, 이미지 3/3
    • Use a plastic opening tool to lift the white clip up, towards the screen.
    • Pull the white cable with blue head, away from the clip.
  3. Disassembling HP Pavilion g7-2275dx Front Panel: 3 단계, 이미지 1/2 Disassembling HP Pavilion g7-2275dx Front Panel: 3 단계, 이미지 2/2
    • With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
    • If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • You should hear clips releasing from the board.
  4. Disassembling HP Pavilion g7-2275dx Front Panel: 4 단계, 이미지 1/1
    • Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
  5. Disassembling HP Pavilion g7-2275dx Front Panel: 5 단계, 이미지 1/2 Disassembling HP Pavilion g7-2275dx Front Panel: 5 단계, 이미지 2/2
    • Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
    • Set aside the top panel until your are ready to reassemble your laptop.
결론
Erik Miller
회원 가입일: 04/22/14
2,123 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G51
4 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 48
