주요 콘텐츠로 건너뛰기
Disassembling HP Photosmart c3180 Top Panel
필요한 것
  1. Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: 1 단계, 이미지 1/2 Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: 1 단계, 이미지 2/2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Disassembling HP Photosmart c3180 Top Panel: 2 단계, 이미지 1/2 Disassembling HP Photosmart c3180 Top Panel: 2 단계, 이미지 2/2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Disassembling HP Photosmart c3180 Top Panel: 3 단계, 이미지 1/2 Disassembling HP Photosmart c3180 Top Panel: 3 단계, 이미지 2/2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Disassembling HP Photosmart c3180 Top Panel: 4 단계, 이미지 1/2 Disassembling HP Photosmart c3180 Top Panel: 4 단계, 이미지 2/2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Disassembling HP Photosmart c3180 Top Panel: 5 단계, 이미지 1/2 Disassembling HP Photosmart c3180 Top Panel: 5 단계, 이미지 2/2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Disassembling HP Photosmart c3180 Top Panel: 6 단계, 이미지 1/1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Disassembling HP Photosmart c3180 Top Panel: 7 단계, 이미지 1/2 Disassembling HP Photosmart c3180 Top Panel: 7 단계, 이미지 2/2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    Änderung des Textes: die kleine Lasche verriegelt die kleine Frontblende: mit leichtem Druck Richtung “rechte Druckerseite entriegeln, gleichzeitig jene Blende nach vorn lösen.
    Garofalo - 답글
  8. Disassembling HP Photosmart c3180 Top Panel: 8 단계, 이미지 1/2 Disassembling HP Photosmart c3180 Top Panel: 8 단계, 이미지 2/2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Disassembling HP Photosmart c3180 Top Panel: 9 단계, 이미지 1/1
    • Carefully lift the top panel of the printer away from the printer body.
    nur die dünne weiße Abdeckung, die graue bleibt noch; zuerst hinten anheben, vorn ist mittig eine Nase zu lösen.
    Garofalo - 답글
결론
다른 11명이 해당 안내서를 완성하였습니다.
Jim
회원 가입일: 10/06/11
1,590 평판
안내서 10개 작성하였습니다
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 회원
CPSU-MANESS-F11S20G30
4 회원들
안내서 25개 작성하였습니다
댓글 한 개
Thanks... Now I'know how clean
Diogo Pires Nunes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 34
전체 시간: 6,509
