주요 콘텐츠로 건너뛰기
Disassembling HP Printer printer cover
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
    • Lift open the scanner cover.
    • Gently pry off the scanner cover support arm. This is the scariest part as the arm is all plastic. There is a small nob projecting into the path of the slider in the middle of the arm. Hold the cover open to minimize contact with the support arm while prying.
    • Carefully remove part of the printer badge on the front right hand side of the printer. Underneath you will expose the first of three hidden screws.
    • On the front left-hand side of the printer is the monitor / display. This is clipped into the plastic printer cover. Reach underneath to squeeze the clips so you can gently pull up and out the three clips
    • Disconnect the flat cable to the display unit and set aside.
    • Take your screwdriver and remove the two screws uncovered by the removed display.
    • Remove the two screws on the left hand side of the printer cover
    • Remove the two screws on the right hand side of the printer cover.
    • Remove the two screws at the back of the printer holding the scanner main hinges in place.
    • Place a support behind the printer with a soft cover (towel will do) to place the scanner.
    • Unhinge the scanner and carefully place on the towel behind the printer (as the cable is still attached).
    • Remove the printer cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gerold Rupprecht
회원 가입일: 05/26/13
155 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,131
