주요 콘텐츠로 건너뛰기
Disassembling Home Stereo and Theater Philips MCD288
필요한 것
  1. Disassembling Home Stereo and Theater Philips MCD288, Undo screws: 1 단계, 이미지 1/1
    • remove the 4 screws on the bottem of the main set
  2. Disassembling Home Stereo and Theater Philips MCD288, Expose main latches: 2 단계, 이미지 1/1
    • Lift the aluminium pane at both sides with a spudger.
  3. Disassembling Home Stereo and Theater Philips MCD288, Start with the bottom edges: 3 단계, 이미지 1/1
    • To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
    • hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
  4. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: 4 단계, 이미지 1/2 Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: 4 단계, 이미지 2/2
    • To detach the sides, pull a main latch towards you and keep on lifting the top part further.
    • repeat for three latches on each side.
  5. Disassembling Home Stereo and Theater Philips MCD288, The inside: 5 단계, 이미지 1/2 Disassembling Home Stereo and Theater Philips MCD288, The inside: 5 단계, 이미지 2/2
    • These pictures show the latches on each edge and on the top of the set.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Philipp
회원 가입일: 03/16/15
71 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 90
전체 시간: 7,518
