주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
How to open up the IBM ThinkPad 560z
  1. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Remove the 7 mm Phillips #0 screws.
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  3. Open the flap on the left hand side. Open the flap on the left hand side.
    • Open the flap on the left hand side.
  4. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  5. Insert the plastic opening tools between the right and left sides of the latch. Pry the right side  of the latch, and then pry the left side to detach the laptop's cover.
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  6. Open the flap on the right side. Open the flap on the right side.
    • Open the flap on the right side.
  7. Insert the plastic opening tools towards the right side of the latch.
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  8. Lift the keyboard slowly. A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  9. Use your fingers or a spudger to detach the connector.
    • Use your fingers or a spudger to detach the connector.
  10. Carefully lift and remove the keyboard. Carefully lift and remove the keyboard.
    • Carefully lift and remove the keyboard.
결론
Derek Driscoll
회원 가입일: 2010년 04월 15일
119 평판
안내서 8개 작성하였습니다
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 회원
CPSU-REGAN-S10S26G27
3 회원들
안내서 18개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,485
