주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Prerequisite: Battery, uppercase, LCD screen
부품
지정된 부품이 없습니다.
  1. Flip the ThinkPad over so that it is upside down. Slide the highlighted tab to the left.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Make sure the laptop is upside down and oriented in the direction shown.
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  3. Rotate the ThinkPad so that the hard drive bay is facing you.
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  4. Flip the ThinkPad over and open the LCD panel. Pry apart the keyboard with a plastic opening tool or with your fingers.
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  5. Be careful not to pull out the keyboard carelessly; there is a connector underneath it! Lift the front end of the keyboard as shown. Using your fingers, remove the black film cover.
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  6. Locate the connector attached to the motherboard. Disconnect the ribbon cable by removing the connector. Disconnect the ribbon cable by removing the connector.
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  7. Lift and remove the keyboard. Remove the two 5.6mm screws.
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  8. You will need to use a little force. Be wary of the tabs. Pry off the upper case with your hands. Pry off the upper case with your hands.
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  9. Remove the 5.6mm screw that holds the LCD to the upper case.
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  10. Remove the 5.6mm screw on the left side of the three-pronged connector. Remove the other two 16.7mm screws. Lift and remove connector.
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  11. Pull out the white tab connecting the LCD to the motherboard. Pull out the white tab connecting the LCD to the motherboard.
    • Pull out the white tab connecting the LCD to the motherboard.
  12. Turn the laptop so that the back is facing you. Remove the four 5.6mm long screws.
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  13. Place the laptop so that the LCD is facing you again. Gently lift the LCD monitor up and out. Remove the black plastic tab.
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
  14. Locate the 4 screws that will need to be removed.
    • Locate the 4 screws that will need to be removed.
    • One screw (yellow) is observable. The three other screws (red) are below the heatsink bracket.
    • Remove the 5.6mm (yellow) and three 16.1mm (red) screws.
  15. Lift the heatsink bracket up.
    • Lift the heatsink bracket up.
  16. Be careful not to pull too hard! There is a cable attached to the fan! Lift the fan/heatsink assembly up. Locate the fan power cable and pull upwards near the connector.
    • Be careful not to pull too hard! There is a cable attached to the fan!
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
결론
Jessica
회원 가입일: 2010년 10월 06일
162 평판
안내서 7개 작성하였습니다
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G44
4 회원들
안내서 26개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,385
