주요 콘텐츠로 건너뛰기
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: 1 단계, 이미지 2개 중 1개 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: 2 단계, 이미지 2개 중 1개 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: 2 단계, 이미지 2개 중 2개
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: 3 단계, 이미지 2개 중 1개 Disassembling IBM ThinkPad A30 Floppy Disk Drive: 3 단계, 이미지 2개 중 2개
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
결론
To reassemble, place the floppy disk drive back into its bay the way it was facing before
작성자
8다른 기여자 명과 함께
Jessica
회원 가입일: 10/06/10
162 평판
안내서 7개를 작성함
Cal Poly, Team 4-44, Amido Fall 2010 Cal Poly, Team 4-44, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G44
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 2,856
