주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Disassembling IBM ThinkPad T42 Lower Bracket
필요한 것
  1. Disassembling IBM ThinkPad T42 Lower Bracket, Bottom cover: 1 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. Disassembling IBM ThinkPad T42 Lower Bracket, Rear screws: 2 단계, 이미지 1/1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. Disassembling IBM ThinkPad T42 Lower Bracket, Keyboard and Trackpad: 3 단계, 이미지 1/1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. Disassembling IBM ThinkPad T42 Lower Bracket: 4 단계, 이미지 1/2 Disassembling IBM ThinkPad T42 Lower Bracket: 4 단계, 이미지 2/2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. Disassembling IBM ThinkPad T42 Lower Bracket, Lower Bracket Removal: 5 단계, 이미지 1/2 Disassembling IBM ThinkPad T42 Lower Bracket, Lower Bracket Removal: 5 단계, 이미지 2/2
    • The metal bracket will now be free to move, grasp it and remove it from the device.
  6. Disassembling IBM ThinkPad T42 Lower Bracket, Remove the Microphone Cover: 6 단계, 이미지 1/1
    • Remove the small rubber piece that is covering the T42's microphone,
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gerald Watanabe
회원 가입일: 04/14/10
279 평판
안내서 7개 작성하였습니다
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G76
4 회원들
안내서 35개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 3,424
