주요 콘텐츠로 건너뛰기
Disassembling IBM WorkPad c3 Back Case
필요한 것
  1. Disassembling IBM WorkPad c3 Back Case, Back Case: 1 단계, 이미지 2개 중 1개 Disassembling IBM WorkPad c3 Back Case, Back Case: 1 단계, 이미지 2개 중 2개
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Disassembling IBM WorkPad c3 Back Case: 2 단계, 이미지 1개 중 1개
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Disassembling IBM WorkPad c3 Back Case: 3 단계, 이미지 2개 중 1개 Disassembling IBM WorkPad c3 Back Case: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
결론
작성자
7다른 기여자 명과 함께
Emily Falkenstein
회원 가입일: 10/05/10
75 평판
안내서 5개를 작성함
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010 회원
CPSU-REGAN-F10S21G35
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 23
전체 시간: 1,615
