주요 콘텐츠로 건너뛰기
Disassembling InFocus LP435Z External Shell
필요한 것
  1. Disassembling InFocus LP435Z External Shell, External Shell: 1 단계, 이미지 2개 중 1개 Disassembling InFocus LP435Z External Shell, External Shell: 1 단계, 이미지 2개 중 2개
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
  2. Disassembling InFocus LP435Z External Shell: 2 단계, 이미지 2개 중 1개 Disassembling InFocus LP435Z External Shell: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
  3. Disassembling InFocus LP435Z External Shell: 3 단계, 이미지 2개 중 1개 Disassembling InFocus LP435Z External Shell: 3 단계, 이미지 2개 중 2개
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
  4. Disassembling InFocus LP435Z External Shell: 4 단계, 이미지 3개 중 1개 Disassembling InFocus LP435Z External Shell: 4 단계, 이미지 3개 중 2개 Disassembling InFocus LP435Z External Shell: 4 단계, 이미지 3개 중 3개
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
  5. Disassembling InFocus LP435Z External Shell: 5 단계, 이미지 2개 중 1개 Disassembling InFocus LP435Z External Shell: 5 단계, 이미지 2개 중 2개
    • Lift away the top case plate and set it aside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Kennedy
회원 가입일: 01/29/13
186 평판
안내서 6개를 작성함
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013 회원
CPSU-MANESS-W13S20G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 1,378
