이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide outlines how to disassemble a JBL Charge speaker’s case. Disassembling the speaker’s case will be useful in repairing water damage, and/or replacing batteries. This guide does not require special skills, besides basic knowledge of common hand held tools.
필요한 것
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
다른 33명이 해당 안내서를 완성하였습니다.
댓글 11개
Breaking apart the halves takes patience. Took 30 minutes. Mine was glued together like a tank, and it was not easy at all to separate the halves. Maybe JBL saw this post and doubled the glue to dissuade DIY fixes. Once I separated the halves, it was easy, but be prepared to get moderately frustrated in doing so. Also, don't get angry and try to force them apart, because from my experience, I do believe there is a high risk potential of cracking either halve if attempting to brute force the issue. Remember, patience is a virtue here. Lastly, you can get a good set of spudger tools at Harbor Freight Tools for cheap. They are actually called Wax Carving tools made in India of stainless steel. Excellent set to complete this fix, and I can see that they will be very useful in the future if needed. 10/10 for the author for the breakdown instructions. Cheers!
Follow these directions, Do not deviate from the path and you shall find Success awaits at journey's end.
one essential moment. when you're trying to disasemble a cover there is also one bolt under the battery socket! it not shown on step 5!
It is told in step 4, but not shown. I looked up this guide when I was stuck after step 5 lol
Btw I am the editor as of Saturday, 27/August/2016. Mine had 4 PH2 screws around the outside and 1 ph2 under the battery. I am not sure if that is how it always was
ion418 -
