주요 콘텐츠로 건너뛰기
Disassembling JVC GR-D290U
필요한 것
  1. Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: 1 단계, 이미지 1/2 Disassembling JVC GR-D290U, Disassembling JVC GR-D290U: 1 단계, 이미지 2/2
    • Open the liquid-crystal display (LCD) screen.
    • Using a Phillips #1 screwdriver, remove the two hinge screws.
    • Remove the hinge cover. Shut the screen after the cover is removed.
  2. Disassembling JVC GR-D290U: 2 단계, 이미지 1/3 Disassembling JVC GR-D290U: 2 단계, 이미지 2/3 Disassembling JVC GR-D290U: 2 단계, 이미지 3/3
    • Flip the camera over to look at the bottom panel.
    • Remove the five screws that are located along the sides of the bottom panel with a Phillips #1 screwdriver.
    • Push the eject button beneath the bottom panel to open the cassette cover.
    • Shut the cassette cover.
    • Place the camera upright.
  3. Disassembling JVC GR-D290U: 3 단계, 이미지 1/1
    • Open the LCD screen. Move the dark gray tab located near the eyepiece aside.
    • Remove the screw located under the dark gray tab with a Phillips #1 screwdriver.
    • Replace the dark gray tab and close the LCD screen.
  4. Disassembling JVC GR-D290U: 4 단계, 이미지 1/1
    • Go to the side of the camera that is opposite the LCD screen.
    • Remove the two screws located on this side of the camera with a Phillips #1 screwdriver.
  5. Disassembling JVC GR-D290U: 5 단계, 이미지 1/2 Disassembling JVC GR-D290U: 5 단계, 이미지 2/2
    • Go to the side of the camera that has the LCD screen.
    • Place the plastic opening tool into the seam between the top cover and the bottom cover of the camera.
    • Pry the top cover from the bottom cover until you hear a snapping sound.
    • Gently remove the top cover from the camera base.
결론
다른 2명이 해당 안내서를 완성하였습니다.
justin chen
회원 가입일: 04/27/10
47 평판
안내서 3개 작성하였습니다
Cal Poly, Team 18-69, Johann Spring 2010 Cal Poly, Team 18-69, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G69
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 3,883
