이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the phone over to expose the battery cover.
Apply pressure to the back of the battery cover to slide it down.
The battery cover is now separate from the phone.
Remove the battery by pushing it up and out from the bottom.
The battery, cover, and phone should now be separated.
Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
Remove the two screws with a Y0 screwdriver.
Rotate the phone 180 degrees.
Carefully separate the back plate from the remainder of the phone.
The back plate should now be detached from the rest of the phone.
다른 2명이 해당 안내서를 완성하였습니다.
