소개
These instructions will demonstrate how to remove the SD card slot from the KDDI Kyocera A5521K.
부품
No parts specified.
  1. Turn the phone over to expose the battery cover. Apply pressure to the back of the battery cover to slide it down. The battery cover is now separate from the phone.
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Remove the battery by pushing it up and out from the bottom. The battery, cover, and phone should now be separated. The battery, cover, and phone should now be separated.
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the four screws with the Y0 screwdriver. Remove the four screws with the Y0 screwdriver.
    • Remove the four screws with the Y0 screwdriver.
  5. Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws. Remove the two screws with a Y0 screwdriver.
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  6. Rotate the phone 180 degrees. Carefully separate the back plate from the remainder of the phone. The back plate should now be detached from the rest of the phone.
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  7. Rotate the phone approximately 45 degrees to the right. Gently pry up the SD card slot with a spudger. Gently pry up the SD card slot with a spudger.
    • Rotate the phone approximately 45 degrees to the right.
    • Gently pry up the SD card slot with a spudger.
결론
Dominic Grisafe
회원 가입일: 2010년 04월 15일
157 평판
안내서 10개 작성하였습니다
Cal Poly, Team 28-25, Regan Spring 2010 Cal Poly, Team 28-25, Regan Spring 2010 회원
CPSU-REGAN-S10S28G25
4 회원들
안내서 20개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 2,808
