주요 콘텐츠로 건너뛰기
Disassembling Kenwood TM-241a Main body
필요한 것
  1. Disassembling Kenwood TM-241a Main body, Main body: 1 단계, 이미지 3개 중 1개 Disassembling Kenwood TM-241a Main body, Main body: 1 단계, 이미지 3개 중 2개 Disassembling Kenwood TM-241a Main body, Main body: 1 단계, 이미지 3개 중 3개
    • Push down on the tab that locks the power connection together, and slide the two connectors apart.
    • Unscrew the antenna downlead from the antenna pigtail coming out of the radio, and pull the two apart.
    • Unscrew the microphone connector from the front panel of the radio, and pull it out.
  2. Disassembling Kenwood TM-241a Main body: 2 단계, 이미지 2개 중 1개 Disassembling Kenwood TM-241a Main body: 2 단계, 이미지 2개 중 2개
    • Using a #1 phillips screwdriver, remove the two screws that secure the top cover to the radio.
    • Do the same to the two screws on the bottom.
  3. Disassembling Kenwood TM-241a Main body: 3 단계, 이미지 3개 중 1개 Disassembling Kenwood TM-241a Main body: 3 단계, 이미지 3개 중 2개 Disassembling Kenwood TM-241a Main body: 3 단계, 이미지 3개 중 3개
    • There are two tabs that sit underneath the sides of the face plate. They have a tendency to break out the plastic over top of them while removing the covers. To help prevent this, push inward on the side of the cover, just behind the face plate as you take off the covers.
    • Lift up on the rear of the top cover, and slide it towards the back of the radio to disengage the three tabs at the front.
    • Repeat for the bottom cover of the radio.
결론
작성자
1다른 기여자 명과 함께
Josh
회원 가입일: 03/22/13
707 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 558
