주요 콘텐츠로 건너뛰기
Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover
필요한 것
  1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: 1 단계, 이미지 2개 중 1개 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: 1 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry off the aluminum drip ring.
  2. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 2 단계, 이미지 1개 중 1개
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 3 단계, 이미지 2개 중 1개 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 3 단계, 이미지 2개 중 2개
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 4 단계, 이미지 1개 중 1개
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 5 단계, 이미지 1개 중 1개
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 6 단계, 이미지 2개 중 1개 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 7 단계, 이미지 2개 중 1개 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 7 단계, 이미지 2개 중 2개
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: 8 단계, 이미지 1개 중 1개
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
결론
다른 40명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Chris Gonzales
회원 가입일: 10/12/14
1,656 평판
안내서 2개를 작성함
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014 회원
CPSU-MANESS-F14S14G28
4 회원들
안내서 22개를 작성함
27가이드 댓글
Well fine job! Just finished and t works!!!
James Anderson - 답글
Instruccion is exelent but I veleave the problem is electric. can you give aidea. dhe machine does’nt work at all
Aristides Aleman - 답글
Thank you! I'm repainting my white mixer a deep cherry red gloss to match my kitchen. These mixers can last 20+ years, if you take care of them. But, who wants the same color kitchen for that long? Bonus: saved $50+ by painting it the color I wanted, rather than pay the extra for a mixer from the colored choices.
Heather Schrader - 답글
Do the motor housing sometimes become to hard to remove? I followed all the steps yet it still acts as if something inside the housing is keeping it from coming off.
Royce M - 답글
Nothing else, only the planetary assembly, and the 9 big housing screws. Once those are off, it can take a lot of jiggling and persistence, mostly because there’s a vacuum between the vertical shaft and the bushing inside. Remember to loosen the cord in case to prevent yanking it accidentally when the cover comes off.
Ariel Cornejo -
댓글 쓰기
조회 통계:
지난 24시간: 75
지난 7일: 489
지난 30일: 2,020
전체 시간: 122,641
