주요 콘텐츠로 건너뛰기
Disassembling Kodak Advantix F350 Back Cover
필요한 것
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: 1 단계, 이미지 1/1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: 2 단계, 이미지 1/2 Disassembling Kodak Advantix F350 Back Cover: 2 단계, 이미지 2/2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: 3 단계, 이미지 1/3 Disassembling Kodak Advantix F350 Back Cover: 3 단계, 이미지 2/3 Disassembling Kodak Advantix F350 Back Cover: 3 단계, 이미지 3/3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: 4 단계, 이미지 1/2 Disassembling Kodak Advantix F350 Back Cover: 4 단계, 이미지 2/2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: 5 단계, 이미지 1/2 Disassembling Kodak Advantix F350 Back Cover: 5 단계, 이미지 2/2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: 6 단계, 이미지 1/3 Disassembling Kodak Advantix F350 Back Cover: 6 단계, 이미지 2/3 Disassembling Kodak Advantix F350 Back Cover: 6 단계, 이미지 3/3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
결론
David Cottrell
회원 가입일: 10/04/11
88 평판
안내서 5개 작성하였습니다
UW Stout, Team 1-2, Zhou Fall 2011 UW Stout, Team 1-2, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,080
