이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn off the camera.
Locate the power switch on the front of the camera below the camera lens.
Slide the switch to the off position.
Locate the 3 screws that hold the back cover to the camera.
One screw is located on the film opener side of the camera.
The other screws are located on the opposite side of the camera.
Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
Open the film door to remove the back cover.
Slide the film door lever to the left until the film door opens.
Use a plastic opening tool to pry the case open until a small gap is present.
Repeat this process at the top and bottom of the film door to loosen it.
Grab the top and bottom of the case firmly as shown.
Gently remove the back of the camera case with a slight twisting motion.
