소개
Outline what you are going to teach someone how to do.
필요한 것
Turn off the camera.
Locate the power switch on the front of the camera below the camera lens.
Slide the switch to the off position.
Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
The first 2 are located on the bottom of the camera.
The last screw is located behind the flash module.
Turn the camera on, and raise the flash module to locate the flash module screw.
Locate the 3 screws on the top of the camera.
These will be removed in the next step.
다른 한 분이 해당 안내서를 완성하였습니다.
