주요 콘텐츠로 건너뛰기
Disassembling Kodak Easyshare C813 Back Cover
필요한 것
  1. Disassembling Kodak Easyshare C813 Back Cover, Battery: 1 단계, 이미지 1/1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Back Cover: 2 단계, 이미지 1/3 Disassembling Kodak Easyshare C813 Back Cover: 2 단계, 이미지 2/3 Disassembling Kodak Easyshare C813 Back Cover: 2 단계, 이미지 3/3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Back Cover, Back Cover: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
  4. Disassembling Kodak Easyshare C813 Back Cover: 4 단계, 이미지 1/1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Back Cover: 5 단계, 이미지 1/3 Disassembling Kodak Easyshare C813 Back Cover: 5 단계, 이미지 2/3 Disassembling Kodak Easyshare C813 Back Cover: 5 단계, 이미지 3/3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Disassembling Kodak Easyshare C813 Back Cover: 6 단계, 이미지 1/3 Disassembling Kodak Easyshare C813 Back Cover: 6 단계, 이미지 2/3 Disassembling Kodak Easyshare C813 Back Cover: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Phillips #00 Screwdriver
    $5.49
    구매
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Disassembling Kodak Easyshare C813 Back Cover: 7 단계, 이미지 1/3 Disassembling Kodak Easyshare C813 Back Cover: 7 단계, 이미지 2/3 Disassembling Kodak Easyshare C813 Back Cover: 7 단계, 이미지 3/3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Disassembling Kodak Easyshare C813 Back Cover: 8 단계, 이미지 1/3 Disassembling Kodak Easyshare C813 Back Cover: 8 단계, 이미지 2/3 Disassembling Kodak Easyshare C813 Back Cover: 8 단계, 이미지 3/3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Susan Marano
회원 가입일: 04/15/10
336 평판
안내서 7개 작성하였습니다
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 회원
CPSU-REGAN-S10S24G22
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 2,366
