주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide demonstrates how to remove the front and back cover from the camera
  1. Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Press thumb firmly on battery door and slide it in the direction of the arrow. Lift thumb allowing the door to swing open. Lift thumb allowing the door to swing open.
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
  4. Turn the camera off by firmly pressing the power button located on top of the camera.
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Locate the 7 screws holding the back cover on. Three screws are located on the bottom of the camera. Two screws are located on the side shown in the photograph.
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Remove all 7 screws: Hold the camera firmly with one hand so that you can still see a screw. Place the Philips 00(Found here)screwdriver into the screw.
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Use plastic opening tools to slightly open the side of the case. Insert a plastic opening tool and apply pressure to the internal three tabs at the top. The first two are near the words "3X Optical Zoom".
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Gently pull apart the back cover from the rest of the camera. Make sure there are no more screws or tabs keeping the cover on. Use the plastic opening tool to separate any sides still closely connected.
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Open the battery door. Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Open the battery door.
  10. Use the plastic opening tool to lift the casing around the shutter button. Gently remove the front cover from the device. Gently remove the front cover from the device.
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Do not touch the terminals shown in the photo.  These link to the capacitor which could shock you if not discharged.
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Susan Marano
회원 가입일: 2010년 04월 15일
316 평판
안내서 7개 작성하였습니다
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 회원
CPSU-REGAN-S10S24G22
4 회원들
안내서 20개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 3,404
