주요 콘텐츠로 건너뛰기
Disassembling LG 440G Rear casing
필요한 것
  1. Disassembling LG 440G Rear casing, Turn off phone.: 1 단계, 이미지 1/1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. Disassembling LG 440G Rear casing, Flip phone.: 2 단계, 이미지 1/1
    • Flip the phone over.
  3. Disassembling LG 440G Rear casing, Rear cover removal.: 3 단계, 이미지 1/1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. Disassembling LG 440G Rear casing, Removal of battery.: 4 단계, 이미지 1/1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. Disassembling LG 440G Rear casing, Unscrew six screws along edges of casing: 5 단계, 이미지 1/1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. Disassembling LG 440G Rear casing, Lift casing cover: 6 단계, 이미지 1/2 Disassembling LG 440G Rear casing, Lift casing cover: 6 단계, 이미지 2/2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
결론
Emily Class
회원 가입일: 02/17/15
107 평판
안내서 1개 작성함
Ohio State, Team 1-1, Buehl Winter 2015 Ohio State, Team 1-1, Buehl Winter 2015 회원
OSU-BUEHL-W15S1G1
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
this would be most probably, the same guide to tear down the LG B470
douglas flores - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,686
