주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling LG VX8550 Front Case
필요한 것
  1. Disassembling LG VX8550 Front Case, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the battery release up.
  2. Disassembling LG VX8550 Front Case: 2 단계, 이미지 1개 중 1개
    • Remove the battery by lifting away from the case.
  3. Disassembling LG VX8550 Front Case, Case: 3 단계, 이미지 1개 중 1개
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Disassembling LG VX8550 Front Case: 4 단계, 이미지 1개 중 1개
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. Disassembling LG VX8550 Front Case: 5 단계, 이미지 1개 중 1개
    • Use the iPod opening tool to pry off the back casing.
  6. Disassembling LG VX8550 Front Case: 6 단계, 이미지 1개 중 1개
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. Disassembling LG VX8550 Front Case: 7 단계, 이미지 1개 중 1개
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. Disassembling LG VX8550 Front Case, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. Disassembling LG VX8550 Front Case: 9 단계, 이미지 1개 중 1개
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. Disassembling LG VX8550 Front Case: 10 단계, 이미지 1개 중 1개
    • Remove the motherboard from the front casing by lifting straight up.
  11. Disassembling LG VX8550 Front Case, Keypad Housing: 11 단계, 이미지 1개 중 1개
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. Disassembling LG VX8550 Front Case: 12 단계, 이미지 1개 중 1개
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. Disassembling LG VX8550 Front Case: 13 단계, 이미지 1개 중 1개
    • Lift the keypad housing away from the slider.
  14. Disassembling LG VX8550 Front Case, Front Case: 14 단계, 이미지 1개 중 1개
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. Disassembling LG VX8550 Front Case: 15 단계, 이미지 1개 중 1개
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. Disassembling LG VX8550 Front Case: 16 단계, 이미지 1개 중 1개
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. Disassembling LG VX8550 Front Case: 17 단계, 이미지 1개 중 1개
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. Disassembling LG VX8550 Front Case: 18 단계, 이미지 1개 중 1개
    • Slide ribbon cable through the slider mechanism.
  19. Disassembling LG VX8550 Front Case: 19 단계, 이미지 1개 중 1개
    • Separate the two halves.
결론
작성자
5다른 기여자 명과 함께
Nathan Jones
회원 가입일: 04/10/10
89 평판
안내서 10개를 작성함
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 회원
CPSU-FORTE-S10S34G55
5 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 65
전체 시간: 2,341
