주요 콘텐츠로 건너뛰기
Disassembling LG Vortex
필요한 것
  1. Disassembling LG Vortex, Power down the Phone: 1 단계, 이미지 1개 중 1개
    • Power the phone off
    • The power button is located on top of the phone
  2. Disassembling LG Vortex, Remove the Back Cover: 2 단계, 이미지 3개 중 1개 Disassembling LG Vortex, Remove the Back Cover: 2 단계, 이미지 3개 중 2개 Disassembling LG Vortex, Remove the Back Cover: 2 단계, 이미지 3개 중 3개
    • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
  3. Disassembling LG Vortex: 3 단계, 이미지 1개 중 1개
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Put the battery aside.
  4. Disassembling LG Vortex, Unscrew the Back Frame: 4 단계, 이미지 2개 중 1개 Disassembling LG Vortex, Unscrew the Back Frame: 4 단계, 이미지 2개 중 2개
    • All screws are the same size screwdriver head #00
    • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in a container to ensure they aren't lost.
  5. Disassembling LG Vortex, Remove the Back Frame: 5 단계, 이미지 3개 중 1개 Disassembling LG Vortex, Remove the Back Frame: 5 단계, 이미지 3개 중 2개 Disassembling LG Vortex, Remove the Back Frame: 5 단계, 이미지 3개 중 3개
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Jen
회원 가입일: 02/13/14
40 평판
안내서 3개를 작성함
Ohio State, Team 1-3, Buehl Spring 2014 Ohio State, Team 1-3, Buehl Spring 2014 회원
OSU-BUEHL-S14S1G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 12
전체 시간: 4,648
